If the PT were shorted, it would freak out even in standby. Yours only freaks out when the standby switch is turned on. Your caps are exxploding. That is not likely the fault of the transformer, all the transformer does is make AC voltages. If you replaced the bad caps and the new ones blew up, then either the voltage across them (wwhich you could measure) is WAY above their rating
ORRRRRRR
you have a bad rectifier sending AC (reverse voltage ) into the caps. I like that second suspect the best.
ORRRRRRR
