Received a tiny terror 7/15W head for repair...power but no sound. HT fuse was blown and output tubes would show an intermittent short on the tube tester when tapped so I replaced the output tubes and fuse. Checked for any signs of components that could also be open but couldn't find anything....Powered it up and same problem...Took the board out to see if there were any signs of bad connections, etc....everything looks good. Searched google for a schematic but nothing came up...I'll check out the schematics section of the forum but just checking here to see if anybody out there had run across one of these amps with this particular problem...
Cheers,
Bernie
Cheers,
Bernie
