Can cap replacement for 78 Vibro champ
  • Can cap replacement for 78 Vibro champ
    Getting ready to do some maintenance on this amp. I can find the parts I need except the can capacitor. The stock is a Malory 40/20/20 at 450. The closest replacement I can find is a CE 40/20/20 but it's rated at 500. I was wondering if it would still work out or if someone had some advice on what to do.
    thanks!
    The higher voltage rating is fine.
    Is there anything 'wrong' with the original can?
    The reason I ask is I have purchased replacement cans that where not up to snuff.
      I've had bad luck with the "CE" branded cans. I don't bother with them anymore.....just use discrete caps in place of the can.
