I have a crest cc2800 on the bench, R33 and 34 were blown to pieces.
Transformer seems to check out fine, making voltages.
With connector J1 from PT connected and J2 disconnected I can bring it up on a light bulb without a problem/
So I suppose the power supply is working, so far.
When connecting J2, the limiter bulb lights up.
Diode check on the output transistors in circuit show they are shorted.
When I pulled Q119 it passes the diode test. Why is that?
B1, F1and F2 check out good.
Anyone have a suggestion as to where to go?
thanks
thanks
