Laney BC 75 schematic ?? Any one have a copy ??
  • Laney BC 75 schematic ?? Any one have a copy ??
    I got a Laney BC 75 solid state bass amp That has no output, power supply issue, one of the 2 4700uf caps was rolling around on the inside. Some one has worked on it before me and replaced many transistors. I replaced the cap yet I got a dead short some where. It blew my light bulb current limiter in about 10 seconds. It is a basic layout but I could use a schematic to check what was done to this thing before I got it. The bridge rectifier tests ok but i suspect it may be a issue under power Thanks
    Try this one out>>>
    BCRange-BC75included.pdf
    Look at pg6 for the power board and I think pg5 was the preamp??
      And look for shorted output devices.
        Will do Enzo ...Thanks for the schemo DrGonz, now I can check and see if they used the right stuff in there. Much apprecieated Time to dig back in
          Can somebody clue me in on how they are pulling 120 watts output with a + - 44volt power supply?
            With 4 ohm load, only 22V RMS is required for 120W, that would be about 62V peak to peak, +-44V should allow for more than 62Vp.p. am I missing something?
              120 watts from a single pair of output transistors is asking a lot. At least from a reliability standpoint.
                I went through it with the Schematic DrGonz kindly posted, someone had worked on this before i got it and replaced all the transistors and such, when I got it it had one of the 4700uf caps rolling around in it. They used all the correct parts the outputs were mj15003's though not the 2n's but compatable. As I said when i posted it lit up my current limiter big time After going over all the replaced parts and re-soldering, one of the power transistors TIP32 I believe was bridged I put the old cap back in it fired it up and it was good to go took it off the limiter and ran it into a 410 8 ohm load and it sounded fine, actually not bad for what it is, and cheaply designed ( nothing holding the board up but the jacks and the 2 heat sink screws ) it thumped pretty good I checked the the voltages 38 & -38 they were one volt shy at 37 then I checked the A & B points which were high but I could only get them down to 11.9mv. . I played it for bout half hour heat sink got a little warm, caps were cool.. seemed to be just fine it is a 1 15 combo and probably should stay at 8 ohms. But road tested well to me , out the door it went... Enzo I did pass along your info to the Lad with the Marshall VM, it is a youngsters and he is cash strapped Im told, this is why I was told to just fix the fx issue though it needs new KT66's and a going through. I left your info and strongly urged him to see you in my write up, but I dont think he has even picked it up yet. I hate when guys say "just do this" when you see it needs some tlc....But I does what I's told
                casinolevant levant casino
