I have a hartke head and a 18" ampeg speaker cab. I'm guessing the problem lies in the specs between the two pieces of equipment (even though the problem just started happening recently and I hadn't had any problems for quite a long time).
Please assist in any way possible to figure out the problem.
After playing the setup for several minutes, the amp makes a whoofing sound as Im playing. It's considerably louder than what the volume is set at. I've been using the set up for awhile and nothings ever happened until now. I thought I fixed the problem several weeks ago because it stopped doing it for a day or so, then came back.
Hartke Model 3500 Amp Head
350 watts
with two 8 Ohms speaker outputs
8 Ohms at 240 watts
4 Ohms at 350 watts
Ampeg SVT18 Speaker Cab
Handling: 500 watts
1000 watts peak
Impedance: 4 Ohms
Thanks!!
350 watts
8 Ohms at 240 watts
4 Ohms at 350 watts
Handling: 500 watts
1000 watts peak
Impedance: 4 Ohms
Thanks!!
