Hi all,
I'm hoping someone can help me identify the source of buzzing I'm getting on my Guytronix Gilmore Jr amp. I'm having a hard time determining if it's the speaker (Weber 12A125-O) or the power section of the amp. The buzzing is worse on the low end and only occurs at a distortion level (power tube saturation).
I have used several different tubes in the power section (6N1P, 6CG7, 12AT7, 12AU7 and ECC99) and the buzz is present with each of them, but at slightly different volume/distortion levels.
I'm a bit limited as to the speakers I have on tap to test out. I tested the amp on two different Hi-Fi speakers in addition to the Weber, and they seem to buzz-out (and flub/fart-out) sooner and worse than the Weber. I have heard that this Weber model might flub out with bass-heavy guitars (my guitar is somewhat bass-heavy), but the speaker is rated at 20W and the amp is only putting out 2W max.
Can someone tell me how I might go about eliminating potential culprits to narrow down the problem?
Thanks for any help,
Tim
Tim
