Help guys,
This amp is driving me nuts.
I have a late 60's fender twin reverb AB763 that has a buzz with all controls at zero that only occurs when I install the chassis into the cabinet.
The weird thing is that it only appears when you tighten the final bolt... the first three bolts do not effect the buzz and it doesn't matter which one you tighten last. Outside of the cab the amp sounds great....
When I pull the reverb recovery tube (V4) the buzz goes away. I've swapped the tube out but the buzz is still there. t.
I've checked all the grounds and everything appears as per the schematic. Any ideas?
