This 80's Peavey Minx 1x10 30 watt bass amp behaves well until the volume is raised very high....a loud static, sputtery noise interrupts the Bass sound. I tried a different speaker....no change. I resoldered everything on the PCB, thinking bad solder joint....no change. I had replaced 2 input jacks, the preamp out jack and the stereo headphone out jack. Resolderd those as well. I just checked and sputtering is there in the headphones, too. It sounds like a loud speaker rattle. But it's not vibration related. Some component must be bad. Any ideas on where to start looking? Thanks!
I just tried a line out into another amp....sputter is present at the other amp as well. So it seems the bad part is before the line out jack
