Hi,
My 3ch recto was fine on Tuesday... very loud and the clean channel was clean. It did blow a fuse (which i replaced with the correct one) I turned it back on to check it was working but didn't play any more that day.
Yesterday it was turned on and was (comparatively) very quiet at the same knob positions. The clean channel (not pushed) is suddenly quite heavily crunched.
Any help? I have electronics experience, my first thought was that the HT has markedly dropped, so first thing I'm going to do is check voltages against the schematic I found online (attached, if I did it correctly)
The issue is the same in vacuum and diode rectifier configs. Diode level is slightly heavier, but I believe that's to be expected any way.
Any help much appreciated.
