Ampeg SB12 volume pot hum... but only when turned down?
  • Ampeg SB12 volume pot hum... but only when turned down?
    I've been meaning to post this here for a bit -- I have a vintage Ampeg B12 Bass amp, one of the old flip tops. It'd been messed with pretty hard when I got it, The OT had been replaced and the new one oscillated like crazy, part of the board had a hole burned in it, bad caps, etc. Slowly but surely I've gotten it back together, but the last hurdle has been an issue with the volume pot. When set to 2-10 on the dial, it's fine, very little hum, volume taper works as expected. But when I turn it down all the way and get to 1 or so, it makes a sound and hums like a bastard, almost as if I'm engaging some sort of hum switch at the end of the pot taper. The pot is a replacement, and the old pot did the same thing. Any idears? There are a few different versions of this amp out there but this schematic is pretty close to the one I've got:
    http://www.freeinfosociety.com/elect.../ampegsb12.gif
    Whoa!
    Forbidden link.
    Can you simply post a copy that you have?
      Well, there is this one:
      http://www.webphix.com/schematic%20h..._portaflex.pdf
      Much as I don't like all these Joe P drawings, they are better than nothing.
      My suspect is not in the schematic anyway. I bet your pot has its ground leg grounded somewher other than the same place the cathode resistors of V1 are grounded. Like to the panel maybe?
        Take your pick.
        The Free Information Society - Media in Electronic Circuit Schematics/Other
