75 Deluxe Reverb
  • 75 Deluxe Reverb
    Just rewired chassis with pushback wire. Now I have a low hum when the variac hits 90 v. The hum fluctuates from quiet to louder.
    All controls off. No guitar cord plugged in.
    When I pull the rectifier tube, ....no hum.
    Ideas ?
    Thanks
    Doc
    Originally posted by Doc Stitches View Post
    Just rewired chassis with pushback wire. Now I have a low hum when the variac hits 90 v. The hum fluctuates from quiet to louder. All controls off. No guitar cord plugged in.
    My first thoughts are power tube or biasing problems. Maybe one power tube going into runaway. Can you monitor the biasing of each power tube as you approach 90V? What happens if you warm it up with 120V line voltage then switch from standby to operate? Set the bias to max cold (most negative voltage) before doing this for the first time and check that the same negative voltage level is on each of the power tube grid pines (Pin #5). Also check for excessive ripple on the B+ and the bias supply.
    That's as expected since there will be no B+and all circuits except the heaters are off.
      Of course the hum stops when you pull the rectifier tube - the amp then has no power supply voltage.
      Why are you trying to run the amp on 90 volts?
        Progress with loud hum
        Just had some time to get back to this DR. and found and resolved 4 more issues
        pin 6 not wired on tube 6 ....I had pushback wire right to the pin, BUT no solder !!!
        Vibrato channel inputs not wired correctly
        Removed .002K capacitor from reverb output
        Replaced both 12AT7 tubes and got rid of another 25% of the hum
        ..........................this amp was a 75 Deluxe Reverb with 2 pushpull pots with a lot of mods...I am attempting to restore it back to AB763
        Almost all hum is gone, but I think I can get it very quiet.............now if I can just get the treble and bass pots to work along with Trem and reverb, I'll happy
        Thanks Tom and Enzo...I'll get to the voltage checks soon, ........................................ and Enzo................I was only going to 70 v with the variac thinking it was the best way to prevent possible damage, because at that voltage the
        hum was soooooooooooooooooooo LOUD.
        You guys are great
        Doc
