I'm starting a fresh thread on the Peavey Triumph, as recommended, since an earlier thread has grown too long. (thanks Enzo).
Symptoms and observations so far:
Although the foot switch LED's respond correctly, the crunch, ultra and reverb functions are not working.
The clean works OK when the bypass switch is on.
There is no sound when either the crunch or the ultra channel is engaged, and no reverb when the reverb switch and pot are turned on.
There is a discernible increase in background noise level when the post gain pot is turned up to max on either the crunch or ultra channel.
The feed to the relay coils is nominally 25v.
The wiper of the reverb pot stays at 0v. when the reverb pot is rotated, whether or not the reverb is switched on.
The schematic shows two types of ground references - plain and circled. What is this denoting?
What should I check out next?
