I searched on here and didnt see these issues.
I have the 212 model.
1st issue = the Resonance and Presence controls dont work --either channel. Ive tested everything in that circuit except c6--have to pull the pcb to test it . What else is there ??? d108/109 test ok in circuit . The cable tests good. Possible solder joint--again i havent pulled the pcb yet..
2nd issue =
with the Boost Gain switch (its on the dirty ch. ) IN , the amp wont go to the clean channel .
with it out , the amp switches channels fine .
I can hear the relay click--but no switching. It should switch from clean to dirty ?
2nd issue =
