This is a continuation from a issue i mentioned in another thread that was not related, so i decided to start a new one. If you happened to have read the thread about my amp changing tone when warm you'll recall the issue turned out to be a bad tube which i found when i tapped one and it arced and the fuse blew. So i put another in leaving the good one and the amp was fine. I have dual bias so no problem with tubes that didn't come together matched. Anyways, i played it several times since then with no issues, but last nite i was playing it for maybe 10-15 minutes and the sound went totally silent for about 5 seconds, then the fuse popped. I wondered if it might be the same side, maybe something on that socket, so i put yet another in there. (all winged C's) It did it again right away. I then wondered maybe it was the other tube and not the one i just changed. Or maybe something in the amp. So i inspected both sockets closely for possible short and read both 1k screen resistors which read fine. I only had one fuse left so i never replaced the one in the other socket. So i stuck a set of EH in and it ran fine for about 10 minutes but i didn't like the tone. So i pulled them and put 2 more winged C's in, ones that were never in it when all this fuse blowing happened and it ran the rest of the nite just fine.
I kept thinking how people have been saying winged C's were not QC'd well, but it would be a heck of a coincidence for this to happen twice in a short time when i have a drawer full of winged C's i have used for years and never one incident like this. So my question is, where should i look for possible reasons for this in the amp? It's basically a 2204 output circuit and it's been dead reliable for a few years, but i recently rebuilt it with pretty much all new everything cept trannys/pots/switches.
