This should clear the air a bit These parts of the schematic were a bit scattered to say the least.
The bias supply comes from the 40volt CT which also provides the I.C. supply + & - 15v.
It is capacitively coupled to the ac via two 22uF 50v capacitors.
Stupidly it shares 2 fuses with the IC supply so if that shorts it takes the bias and the tubes with it !
