I picked up an old Voice of music 162 amp (5 watt with 6AU6 input and 6AQ5A power). The input runs through a pot as voltage divider and then heads directly to grid of 6AU6. When I run my iPod into it (just one channel, not summed) it sounds choppy and gaty and weak in low end from 0 to halfway. From halfway to full it starts sounding better and with volume pot cranked it sounds awesome it's just too loud. Turning the volume down on the ipod results in the same issue once you get the volume to a more reasonable level.
I tried multiple tubes and all voltages seem to be reasonable.
Can any point me in the right direction? All I can think of at this point is as you change the volume you change the input impedance of the amp. So perhaps as you get a lower input impedance the ipod starts to freak out? Yet I get the chopped gated sound when leaving amp on full and turning ipod down.
