Hi, I have a "Danelectro Challenger Series S" amp that is not working (like this one: http://kilback.net/pics/Image2.jpg). It seems like there are no schematics available but this thing is different from anything I have ever seen. The volume pot and tone stack are before the first gain stage. Also the filaments of V1 are fed with ~5VDC across pins 4 and 5. The second tube, which seems to be the phase inverter is some kind of octal tube with no visible model name or such. I t seems like the problem is located somewhere around V1 but since I have no experience with such a configuration I don't know where to start. All I have done so far is to replace the old caps and to clean and test the pots. The amp has been tinkered with so I don't know if the wiring is correct at all. Are there similar amps out there with schematics so that I can start somewhere?
ans ideas? ... I'm lost
thanks!
thanks!
