Hi there,
I'm new to this forum--the experience here looks impressive! Could anyone please make suggestions for the following questions/issues? My amp is a Fender Silverface Deluxe Reverb ~1977 to 79. It has a mix of tubes - The rectifier, 6V6s and some of the 12's are stamped original Fender, one of the 12's is Electro-harmonix, and one named "Made in China".
The amp has a couple of noise issues:
A) There's a constant "ticking" or "popping" noise; it comes on as soon as the amp warms up. It happens ~4 times a second, and seems to get a little louder over time (or maybe I'm just turning the amp up ;-). There's no apparent line noise on the 120VAC power from my house.
B) The amp just doesn't have that Fender "sparkle" - tone seems a little muffled, or muddy; just not the high-end/chime I'm expecting.
C) There is some constant (slightly annoying) pink noise along with the ticking.
D) Is a little bit of 60-cycle hum normal? It's not so loud to be distracting, but a low background noise when idling. (If it had a "line-out" it would be unusable).
E) one of the 6V6 power tubes is glowing brighter than the other - the metal disc inside the tube (near the top) is glowing, almost red.
Does this mean the power tubes need to be biased? is there a difference between biasing and balancing? Could any of these symptoms be related? Is there a step-by-step online (or book) toot on how to find/replace the balance pot with a bias pot? tapping the tubes w/ a pencil doesn't create any change (bad or good) to the noise.
I'm a newbie to these type of tube amps, but know which end of a soldering iron to hold, to use one hand when poking around plate voltages, and the importance of discharging filter caps.
Thanks very much for any advice!
