Got a Kustom 150 that had Q5 blown and it's emitter resistor R22 burnt open.
Looks like the output 3055's Q18 & Q19 were replaced sometime in it's lifetime, and they tested good. Q5 and Q6 were also replaced with T0220 TIP31 and TIP40-something.
So I replaced Q5 & 6 with proper rated T039's and swapped out Q18 & 19 with MJ15022's.
Amp works fine, but all of the above transistors are a bit warm, voltages and current through the output devices all look good, power supplies clean.
Just curious if this is normal for the output drivers to get a bit warm.
I was thinking of replacing Q12 & 16 (2n3055's) also with 15022's.
