Hey All,
I’m starting on some maintenance tweaks on my SF DR, and I’d like to make sure I don’t kill myself. Here’s questions that have come up:
A) If I unplug, turn off, then discharge the filter caps in the PS, does that insure I’ve removed all lethal voltages anywhere else in the amp?
B) Another source said to short the plate voltages in the preamp stages to ground. Is that necessary once the PS caps are discharged?
C) I read somewhere else that negative bias circuits can also store ~50vdc; and the (-) side of the electrolytic needs to be shorted to ground. Is that true?
I have some background with electronics, tubes, and 480VAC systems that would inject modulated data signals into industrial building wiring. So I have a healthy respect for lethal volts, just need to make sure I’m safely discharging these amp circuits so I can work on them.
Looking forward to any input - Thanks very much!
David Vinson
David Vinson
