Working on a new homebrew amp. 30 watts, Class A-style, 4xEL84, cathode biased, GZ34 tube rectifier. Circuit based on Marshall 18 watt-style PI w/doubled power tubes. Using an AC30 tranny set. Preamp is modded 800-style.
I have power and preamp grounds seperated. "Power" grounds (B+ CT, plate and screen filters, power tube cathode resistors and filament resistors) grounded on power tranny bolt. "Preamp" grounds (PI, preamp cathodes, filters and pots) on a ground buss screwed down near input.
Got a 60hz hum. Low-level, does not go up/down/change with volume.
No center tap on filaments. 2x100 ohm resistors-to-ground instead. Have changed those. No effect.
Tried pulling tubes, one at a time. V1 pulled, no change. V2 pulled, no change.
V3 (PI/driver) pulled, HUM STOPS. This makes me think hum is centered around the PI tube/circuit. Yes?
Tried swapping tubes, no change, still hums.
Tried replacing all caps and resistors in PI/driver circuit, no change.
Tried swapping power tubes, no change.
Tried cleaning up lead dress in several places, no change.
Tried grounding filter cap for driver in a different place, no change.
Tried swapping OT primarys, no change.
Could this be filament hum?? If it's in the audio, where could it come from? Why wouldn't it stop when I pull V1 or V2 (preamp tubes)?
Running out of ideas to try. Please help!! Suggestions??
