This amp has a bit of 60Hz hum coming from the preamp PCB. Engaging the EQ section with a low freq. boost or engaging the tube section increases the volume of the hum greatly. Swapping tubes does not help. I fixed a cracked solder joint on the preamp PCB and corrected a factory solder bridge too, but it still has the issue. The owner said it always had a bit of hum, but not this much. The inputs are isolated from the chassis. Any ideas?
All the power supply rails look fine on the scope. The amp works fine otherwise.
