Hi,
My super reverb reissue has crapped out in the vibrato channel.
The first channel works fine. As the volume knob is turned up from 0-10 the volume peaks at 5 and then sinks to nothing as you go all the way to 10.
The big tube on the left (facing the back of amp) is making a "loose filament" type of noise as well. problem started after after traveling to a gig then got worse to this point I describe after the return.
What to do.
Also, can't I switch some preamp tubes and make the vib ch. work again?
What to do.
