Looking for info on Ampeg B4
  • Looking for info on Ampeg B4
    I'm looking for info about Ampeg B4 bass amp - the old version, not the new one B4R. I need schematic and information on power handling. I've got one here with a complain that it looses power when used in a bridge mode. Each of the power amps uses 4 pairs of IRFP240/9240. In stereo mode I can get 38V@4 Ohms, and in bridge mode I get 76V@8 Ohms. It seems to me that this are reasonable figures. And I doubt that with only 4 pair of MOSFETs the amp can be used @2 Ohms stereo and @4 Ohms mono. I cannot test the amp for a longer period of time because I don't have a dummy load that could handle such power. Within 2-3 minutes nothing wrong happens.
    Mark
    This is all that I could find.
    "the amp is rated rms power ouput (2ohms) 500-watts x2
    (4ohms) 340-watts x2/1000 watt
    (8ohms) 205-watt x2/700 watt mono"
    76 volts at 8 ohms sounds correct.
      Thanks,
      This is exactly what I've seen. I get 340Wx2@4Ohms and 700W@8Ohms mono. The main question is whether the amp can work @2 Ohms stereo, or @4 Ohms mono. Looking at 4 pairs of MOSFETs I doubt it. The owner of the amp tries to run it @4 Ohms in bridged mode.
      Mark
