delete
Marshall DSL short ???
Originally posted by valvehead View Post1st question-- which wire on the secondary of ot is the common/ground ? Orange or black ? No colors on the scem.
Ok, i jsut tried using a jvm ot with this amp--it worked but sounded very thin--obviously not compatible.
So i just received a new jcm 2000 ot.
Ive got it clipped in, and when clicking on the standby to run--i get a big flash at v4 tube socket and it blows the ht fuse--this is with no tubes . I also have a light bulb current limiter in line !
Ive triple checked the wiring. Ct wire is blue , plates are white and purple.its easy to see where they go on the pcb.
I have those correctly clipped to the new trans--wiring is correct. The secondary is not hooked up. New trans is a classic tone = ct is brown, plates are white / red.
I had the pcb out this week and everything looks good there.
Im stumped because the amp worked with that other trans yesterday !
Any thoughts ??
I guess i will pull the pcb again and inspect-----but again..it worked with the other trans..
edit---the spark is under v3 socket-----the one i replaced.....im pulling the pcb--and i bet i will find the problem....
Is it the power tube next to the power transformer? Pins 3 and 4? There is a small disk cap between those two pins on that one socket only. It can short.
Or do you have an actual arc - a burnt spot?Education is what you're left with after you have forgotten what you have learned.
It was the 3rd power tube socket ...i removed that cap last week from v8...i know all about that lil bugger.... it was a short somehow from pin 3 and 4. I replaced the socket and dremeled out some pcb in that area---amp is up and running now. Ive been fighting this amp for 5 hours straight tonight......gremlin after gremlin....the rectifier for the 1st 2 pre tubes actually went out during this fight.......and by some magical luck--i had a new one here. BR12. Man....what a long night...the amp is working.........until tomorrow. Im afraid to turn it on !
