I'm fiddling with a single-ended 6v6 circuit (ala 5F2). I have one of those problems that may have gone unnoticed (rather than a new problem). When playing higher notes (550hz) with humbuckers, I hear a little unpleasant distortion - a kind of hard-clipped, ghost note. Hitting chords produces no ill effect (or masks it). Lower output pickups don't produce this effect.
I've ruled out speaker and tubes. Preamp and power amp voltages look normal. It doesn't sound like the crackle of a cold solder joint. I'm left looking at this circuit's lack of NFB and the cathode bypass on the second stage. Both cathodes of this 12ax7 are bypassed with 25uf/1k5. I like to be more informed before making blind modifications, so I ask if this something to explore. This amp is a little gain monster, but I wonder if it's a little over the top.
Again, this subtle issue only occurs with cranked volume, humbuckers, and single high notes. Any input is appreciated, as always.
