Hi folks,
This amp came in with cooked R59 / R53, also CR11was open. R52 was charred a little measured ok...
I've replaced R52 | Q31 | R55 | Q33| R56 | Q32 | R53 (the whole bias string bar the trimmer).
Also replaced R59 and CR11 (used a 85C15 as I had one at hand) + CR12
I'm unable to adjust trimmer to bias into cutoff (which the left channel is capable of)
The waveform (image attached) clips from 30v pk-pk upwards (measuring output across a 4 ohm load).
The clipped waveform can be traced to pre-VAS, but is probably visible here due to nfb.
After dissapating 26 watts across 4 ohm load for 20 mins heatsinks get very hot to the touch.
V+ rails are @ + and - 67 v with no signal.
PRO2400 & Digitech G300 Schematic.pdf
My hunch is Q18 and/or19 is bad as clipping is just on negative portion of waveform. Any suggestions?
Ta
Matt
Ta
Matt
