Sunn Beta Lead - Random but relatively constant crackle on output
  • Sunn Beta Lead - Random but relatively constant crackle on output
    Sunn Beta Lead solid state amp, based on date codes I'd say amp is late 81, early 82.
    Sounds very close to sound of a very dirty pot but its not a pot.
    It's there with or without audio, and with all volume/gain/level controls at zero or turned up.
    I've retentioned the output transistor sockets, removed all caked on flux, cleaned the board, hammered on it with my paint stick - no change.
    Have cleaned all jacks and pots.
    Doesn't seem to be temp related, can heat it up or cool it down, let it sit for a while - still there.
    Filter caps are new. +-15 is reading about 12.5 each, have about 1.5v saw tooth on the 30v supply caps.
    I haven't resoldered the board yet, and there is a 4558 used as part of the DC control feedback, was thinking about popping too but thought I would check here first.
    I do have a schematic if anyone wants to look at that, BTW what happened to all the schematics that were on the site? Overrun with clear.gifs
    First of all, plug something into the power amp in jack on the back panel. Does that silence the noise? If it does, that means the noise is coming from the preamp.
    The +/- 15V rails should be higher. Check that the collector voltages on the pass transistors (Q1 and Q11) is about +/- 30V, otherwise something is drawing too much current.
    What did you mean
    ??? The big caps C16 and C17 should have about +/- 40V.
      "First of all, plug something into the power amp in jack on the back panel. Does that silence the noise? If it does, that means the noise is coming from the preamp."
      Yes, noise still present, definitely in the power amp.
      Good call on Q1-Q11 collectors, Q1 has 31vDC, Q11 is at -39vDC. The 15v zener seems to be doing its job with ~15vDC at the base of Q11.
      Sorry, 40 (not 30), the large caps are both close to +/- 44vdc
        You likely have a failing transistor. You'll need a scope to localize the source of the racket, but you may get lucky with freeze spray.
