Hello all,
My arch nemesis Fender Pro-Tube Twin (4x6L6, 7x12AX7 1x12AT7) is causing a problem again.
The amp stopped working suddenly during a show and I have since diagnosed the problem to be a heater voltage of 4.6V when all the tubes are installed.
This amp belongs to my bandmate, and I noticed it had a low heater voltage last time I worked on it, about 5.7 volts, but couldn't see a way of rectifying it, and it seemed within tolerance, so left it.
If I disconnect the heater taps and leave the HT connected, the heater winding reads 6.5V.
If I disconnect the HT and leave the heater taps connected, the heater winding reads about 5V.
If I disconnect the HT and leave the heater taps connected for the preamp valves only, the heater winding reads about 5.8V.
Does anybody have any suggestions? Has the PT finally given up? The amp is regularly used on full volume so is often "under stress".
Any help/suggestions would be much appreciated!
Harry
Harry
