Peavey Special 2x12 power supply is bad is this an easy fix
  • Peavey Special 2x12 power supply is bad is this an easy fix
    I have a Peavey Special 2x12 and the power supply is bad. Is this an easy fix or am i going to have to just pay to get it fixed
    Is this the one? Hoping this attachment will work: Peavey_Transtube_Special_212_orig_1995_schematic.pdf.
    No, the power supply is not especially complex but I suspect that you don't know for sure that it is the power supply.
    How easy it is is only a question you can answer. if you've have no electronics knowledge it's probably better to hand it over to someone who has.
      Hi Mike, welcome to the place.
      Asking us if a "bad" power supply is easy to fix is like asking us if it is easy to fix your car if it "makes a noise." It really isn;t very specific.
      What exactly is wrong with the amp? And how did you decide the power supply was the cause? You could have anything from a simple blown fuse up to major damage.
      I agree with nickb, if you don;t know what you are looking at inside the amp, you should refer the repair to someone who does.
