Hot Rod Deville III making random noises and will go into oscillation when bright switch is engaged. I can touch the insulation on the right shielded cable from main PCB to V1 and stop the oscillation. I have checked both shields, resoldered the ribbon cable. Problem persists. Anyone else seen this?
Hot Rod Deville III V1 random noise and oscillation.
Originally posted by jvm View PostHot Rod Deville III making random noises and will go into oscillation when bright switch is engaged. I can touch the insulation on the right shielded cable from main PCB to V1 and stop the oscillation. I have checked both shields, resoldered the ribbon cable. Problem persists. Anyone else seen this?Experience is something you get, just after you really needed it.
