Here's some pix of my old vintage Ace Tone Duetto amp - circa 1963 I believe from studying the history... played like BUTTER until this afternoon when suddenly had some noises - then SILENCE. Tubes are all lit up fine? The Speaker has a transformer on it (?) I'm NOT an electronics type although I do electrical (110/220). I do have an ohm meter...
Where do I get a transformer like the one shown? Is that it? I'm reading some weird voltages (set my meter on AC - 110) on the 3 incoming wires but reading nothing on the 2 going to the speaker(?) What should I be reading?
The Ace Tone came almost MINT (Ebay deal a year or so ago). The only thing not working was the TREBLE input on the front. I figured screw-it. While checking "her" over I discovered there's a double fuse holder - 1 was missing a fuse... I figured that was the TREBLE channel problem - no fuse. I checked my fuse and it read continuity so I tried using tin-foil on the empty slot (I know I'm an idiot 'eh) and made a fuse - turned it on - NOTHING - no light - NOTHING - no noise either... I removed the tin-foil and still nothing - checked the good fuse and now it's dead - no continuity...
So had to use tin-foil now to check it out. I'll get a fuse (what size? can't read anything on it?). But why no sound? Is it the trannie on the speaker? I have 2 amp techs close by - but both charge a lot and both say 2-3 weeks backlog... fixin' to email a guy advertising on Craigslist here and he says $35 per hour so maybe he's a bit cheaper... but I'd like to figure this out and save the money 'eh.
The Ace Tone is whisper quiet - no hums or issues - and when cranked up (she's a 15-watt I'm guessing) IT SOUNDS LIKE A BLOODY PLEXI
The Tremelo and Reverb all work fine too so shes worth fixing. I have other vintage tubers and they all sound good but this baby looks new and is quiet as a mouse and worth fixin'. HELP!
