Tom...Olddawg...thank you -
I actually found a post of Toms that had some scope links in it.
I will be taking a look a those and my manual.
I should be able to figure it out. If I need help with something specific, I can ask you guys later.
This is the scope I have. (below) I am sure it is pretty cheap. But the only other scopes I could afford were the Techtronix that are all quite old by now. Nothing against that, but I just do not know enough about test equipment to buy an "old" scope.
Thanks Again
Model 2120B, 30 MHz Dual Trace Analog Oscilloscope With Probes - B&K Precision
Thanks Again
