Greetings all!
I'm new here but i'm hoping somebody could help me with some troubleshooting.
I recently took delivery of a Weber Hiwatt clone, upon build completion i fired the amp up (which sounded excellent, i may add) and played at a reasonable lounge-room volume.
I noticed that the kt-66's were producing quite a lot of heat and glow, i attempted to test the bias with my biaspro but didn't get a reading on my multimeter?
i set the bias pot below (or so i would have to assume was low by backing off both bias pots) until i noticed an odor being produced by the amp, then suddenly the 2 amp/250v mains fuse blew.
i let everything cool down, replaced the fuse and instantly blew the new fuse, i removed the amp from its cabinet and began so inspect solder joins, looking for scorched caps etc when i realised that the sticker logo on the weber copper cap was flaked and charred, is it possible this is burned out causing the amp to short upon start-up?
also, how is this possible when the bias was set as low as possible? (without being able to obtain a reading)
any information that can help me out is much appreciated
![Smile](https://music-electronics-forum.com/core/images/smilies/smile.png)
