God afternoon. Have this fender 75 which i just cleaned up...Somebody had 12AX7A's in place of the 12AT7A's that were supposed to be there. Noticed that when I pull the mid pot out the volume increases a fair bit and the sound seems overly bass heavy...Also once the pot is pulled out, there seems to be no adjustment on the mid range control. Push the switch back in and the sound returns to normal and the pot then controls the mid range freq. Looking at the schematic, this switch basically just shorts out a .0047 uf cap and a 100K ohm resistor... and everything checks out fine.....Is this normal for this amp as I have not had any experience with this particular model of Fender amp......One side of this pot is connected to the center lug and looks like it was original...The pot is definately original.....
Cheers,
Bernie
Cheers,
Bernie
