Hey,
I joined this forum today and I'm a hobbyist guitar maker from Australia.
I recently purchased a 2nd hand H&K 6L6 for $850 to use in my guitar making shop for testing guitars as they came off the bench and for some gigging (they retail in AUS for between $1900 and 2400 not including shipping/ postage)
When I tested the amp before I bought it I didn't hear any audible issues with the amp but when I got it home and plugged in a different guitar I was getting this odd metalic oscillation/ rattle not dissimilar from a spring or filament hitting glass that was audible when playing individual notes that had more bass in them (String A an D frets 6-10 were worst). So I instantly thought tubes or reverb tank (leak/ crack or the tank was cactus) were gone. I found out after calling around that the reverb tank would apparently cost around $70 to replace the part and roughly $80 per hour to fit it.
I then plugged in the guitar which I tested the amp with when I purchased it and got the same rattle. Crap!!!
I had the same issue with my H&K 20 watt (which was rectified under warranty and still works fine after 5-6 years and I adore the tone of which is why I bought this one as the price was right).
I replaced the preamp tubes (there was no audible difference) same issue...Then I tested the 6l6 tubes by lightly tapping them with a piece of plastic whilst playing the notes causing the oscillation (nothing audibly different occurred here either). Putting my ear closer to the electronics enclosure I realised it sounded as if it was coming from in there (where I would imagine the reverb tank is also housed as it is not housed on the bottom of the cabinet like some Fender Style Amps).
So the next step would be to take it to a technician and spend probably between $80 and $100 to diagnose the problem and suggest a solution. Which I will be doing. But before I do that I thought I'd chuck it on a forum and get another opinion...
So the question I pose is:
If this is a design flaw with combo amps/ the specific type of reverb tank/ tubes being so close to the dual speakers in higher wattage combo amps (60 Watt) would it be a better idea (or even possible) to MOD the amp by separating the head and the speakers into two separate cabinets. I.e. removing the valve head/ electronics and making a box for the valve head, reverb and then using the factory cabinet with the speakers provided as the speaker cab. Thus potentially avoiding future reverb issues down the track...Could you hypothetically ever just remove the reverb tank and use a pedal instead? Or is the reverb a crucial part of the circuit? I have practically 0 knowledge of valve amplifiers/ their electronic make up.
Any suggestions are much appreciated,
Stuart
Stuart
