SWR 400 Working Pro
  • SWR 400 Working Pro
    I have 400 swr working pro . The coolinfg fan has stoped working . The schematic Im looking at doesn't give the voltage value as well as to if there is asensor to control fan ? HELP have a shoew in 5 days. Thanks
    The schematic Im looking at...
    I'm trying hard to the point of bleeding eyes yet I can't see it.
    Maybe I'll need new glasses
      It would help if you posted the schematic.
        yes, please at least identify the schematic you have.
        Have you tested the fan itself? Unplug it from the system ( or unsolder the wires) and feed it voltage from batteries or a bench supply. Should be a label on the fan telling you the voltage it wants. If you just feed it 12v, it ought to spin.
        The schematic I have says FAN CONTROL CIRCUIT, and by the connector for the fan it says 6-16vDC. That varies with temperature.
        On one side there ought to be three squat filter caps at one end, and a couple small power resistors up on legs. Ther should be two tiny white wires soldered nearby to a spot marked TC1. The wires run over to a part on the heat sink. That is the temperature sensor.
        casibom betturkey
