Kustom 4 terminal pots
  • Kustom 4 terminal pots
    Does anyone know a UK suppler of the 4 terminal vertical PCB pots used in the Kustom HV-100 (12mm 250kA, D shaft)? Contacted the importer but referred back to the US.
    Only three lugs are connected. At a push I could modify standard pots or bend the legs, but the correct part would be easier.
    Find out what they are first, that might make it easier to find in the UK. I see things of that description in Mouser. Alps, Alpha, others.
      Just re-checked the measurements and they're 11mm. They look like they could be ALPS - what do you think?. Don't want to remove them until I have replacements, though.
        They are Alps copies...and really cheap ones at that.
          I'll go with that - they're pretty much worn out after very little home use.
