This may seem like a crazy question -- I understand the need to keep capacitance out of an amp's output stage in order to avoid an impedance mismatch at the speaker, but what is the danger of running something like a diode there? I've gotten some fun fuzz tones by running a diode in parallel to the NFB resistor, just wondering if this is going to damage the OT. Thanks!
Negative Feedback Question
It depends on the circuit. Can you provide a drawing. diagram or schematic??? Adding a diode to an NFB loop COULD send watts to circuit not designed to handle it. I'd need to see what's actually being done before endorsing it."Take two placebos, works twice as well." Enzo
This one is kind of a bastardized version of the Fender 5C3 schematic: http://www.davidsonamp.com/sf/images/deluxe5c3.gif
I don't see a diode in the above schematic so I'm still not clear about the circuit. But just speculating, a diode in the NFB shouldn't tax the power tubes because the relative impedance of the circuit is much higher than the speaker load. It may do funny things to the speaker damping due to NFB. And THAT may change the ideal load impedance. But I don't think there is any danger to the tubes."Take two placebos, works twice as well." Enzo
Originally posted by cryptozoo View PostInteresting... so it's potentially taxing to the power tubes? Doesn't seem like it would generate more voltage, and in fact it's noticable quieter when engaged. I guess that's because half the waveform is getting lopped off!
I would imagine that the peaks on one half of the output waveform are severely attenuated and the 0.6v or so forward voltage drop will introduce a step in the leading and trailing edge. Bit like crossover distortion. You could make it even (...worse!) with anti-parallel diodes.
I'm in agreement that the impedance of the circuit is unlikely to have any detrimental effect on the OT.
Have you got a scope and signal generator? - I'd like to see a pic of the output.Last edited by Mick Bailey; 06-25-2013, 06:51 PM.
