Orange Rocker 30 OT Replacement
  • Orange Rocker 30 OT Replacement
    OK guys...
    I have an Orange Rocker 30 that sounds fantastic just like it is. However, I tried to play out with it and found it a little thin and getting lost in the mix. Just not quite loud enough.
    FYI, the output is cathode biased 2xEL34.
    So.... I have Classic Tone 50W OT that is for a Marshall Plexi/JCM application that's well suited for a P/P pair of EL34's. I wired that guy in there, not seeing any real harm, and it absolutely thumps now.
    I see no harm in it, but I am a hobby guy with a fair amount of tube experience but nothing like some of you guys who really live and understand this stuff.
    What (if anything) is the real risk of having a larger OT in the amp? I have played it for several hours now with no excessive heat, strange behavior, overtones etc.
    Well, the Classic 50 watter has more iron.
    That in itself may be providing a better bass response.
    Hard to tell what happened.
    The Orange OT was crap/ the Classic is simply better.
    As long as the impedance ratio is the same, there is no harm in using a higher wattage transformer.
      Thanks for the input. Yes, the Orange OT is a tiny little thing that sounds as thin as it looks. The overall character of the tone is really nice, just sounds little.
      I used Classic Tone iron in a Plexi clone that I built so I knew it was a quality piece.
      I figured since the impedance was correct to the EL34 pair it would be OK. Just wanted to get some input from more experienced folks.
