I completed a Trainwreck Express recently. It works well and I've been running EL34s in it for a few weeks since completion. Tonight I put a pair of new, tested JJ 6V6s in it for the first time. I was setting bias and went to check plate voltage. My probe slipped from lug 3 (plate) to lug 2 (filament). Apparently I shorted them and pulled my probe away immediately but there was a green arc that continued for about 2 seconds with an accompanying hum before I hit the power switch. The lug for the plate is partially burned away, vaporized! And there is a clear burn spot on the lug for pin 2 where it was arcing to. The fuse didn't blow. The filament winding has a grounded center tap.
I've never experienced this before so before I power it up again I would really appreciate any feedback as to where to check for possible damage before I put another set of tubes in as I don't want to cause any further unintentional damage.
