This amp was sitting in somebody's garage for years. I replaced the 6l6 output tubes, cleaned the pots and fired it up. The high gain channel didn't work. Well, it was real weak and sounded really bad. So I snooped around and found that the plate resistor on V1a was open. I replaced the filter caps and the 100K 1w plate resistor, in fact I replaced 6 of them. I plugged it in and turned on the power switch and no tube glow on any of the tubes. When I pull the tubes and turn it on, I have 6.3VAC where I should. Any Ideas?
Thanks in advance.
Thanks in advance.
