Hello,
with respect to the brute force cheapo zener regulator ciruits, I have found in some of the Crate amps, that the amount of current that is needed from the +- 16v circuit is much much less that the current feeding the zeners.
Years ago I think the standard in a standard voltage divider was to have the resistor to ground (or zeners in this case) drawing 4 times the current the circuit would require.
I've been able to increase the dropping resistors without any affect on the zenered voltages even under the most taxing switching or whatever is drawn through those dropping resistors. I've even dropped the a/c input with Variac & have not had issues with the voltage at the zeners even close to causing the zenered voltage to drop. When you're dropping 40volts down to 16, there's a lot of headroom to keep those zeners conducting.
In one Crate amp I was able to raise the value of the dropping resistors enough to replace the 10 watters with 5watters.
I don't usually believe in redesigning things but I have to think someone blew it with these zenered supplies. It's just way too much wattage being dissipated for the current needed on the +-16v lines.
Now I don't know about this particular Fender...you'd have to experiement. glen
