I am hoping this is not a case of bad OT as a tech buddy of mine has suggested...
The amp is a newish Ampeg j12t. It sounds pretty good most of the time, but it has an intermittent problem with cutting out when it is taking a large strum from my Fender telecaster humbuckers. It will come right back if I mute the strings. So it doesn't lock up completely. The guy who brought it to me just got it on ebay. He says the problem is happens more easily when he uses a pedal. I could only get it to lock up when it was wide open and I couldn't do it consistently.
I'm thinking maybe blocking distortion with a bit of ultra sonic oscillations and my friend (who repairs gear for a living) thinks it's a bad OT.
This amp has 22K grid resistors and a 250 pf cap accross the EL84 power tube inputs. I was thinking the grid resistors could be almost doubled and the cap moved (or added) to the plates of the PI as a starter fix.
It seems odd to me that the sound would cut out and that the OT could be 'bad'.
I have not tried new power tubes yet.
Anybody seen this problem and have any suggestions for a cure?
thanks,
Marc
thanks,
Marc
