Ive got an old transistor radio (a Radio Shack Flavoradio) which i bought as not working. I thought maybe the speaker was blown so i plugged it into headphones and it works fine. I opened it up and measured the speaker and its blown (infinite resistance).
Then, I thought it would be a good idea, while i was there, to make sure there was some voltage across the speaker terminals (in case the jack was corroded or something and was disconnecting the speaker even when not plugged in)
And the speaker has 9V DC (the battery voltage) across it, and so does the headphone output.
So i guess this means im lucky i didnt fry my headphones?
Is it a fair comment that the most likely problem is aged/leaky capacitors? which are passing DC that they should not be passing?
If this is correct, is it more likely to be an electrolytic or a ceramic? i would have thought an electrolytic.
There are 5 small electrolytics in the radio, it would not be much of a hassle to change them all.
How likely is that to solve the problem?
