i've got a marshall 1x12 combo here, my friend found it at the curb w/ some garbage while walking his dogs. i told him i could probably fix it for him.
anyway, it makes sound, but not very loud. with everything up all the way you can still talk over it. but all of the EQ and volume controls and buttons seem to be responding as they should. i tried it through another speaker and w/ another 12ax7, neither helped the issue. i plugged a signal generator into the return of the effects loop and still had the same issue, so i'm guessing the problem is in the power amp.
i'm looking for a schematic so i can check voltages, and if anyone has any suggestions as to a likely culprit, that would be great!
thanks.
thanks.
