Hi all,
I am repairing a Marshall YJM that has a faulty Hi channel I input. This is the input that is routed through a switchable boost (probably a DOD 250 circuit). This Hi input is very dull while the low input of this channel is bright as it should be. As a consequence, the issue is probably located on the "boosst" board which is all CMS. the switching is done through a relay which seems to be fine. Also, i can test continuity from the input jack (jack inserted) throught to the first grid 68k resistor located at the side of valve 1. Sale for the ground connection: no problem here. The input impedance seems to be fine as well (the dullness doesn't seem due to a drop in input impedance as it is higher than 1MOhm).
If anyone has the schematic, it would be of great help!
Thanks in advance!
Thanks in advance!
