A friend's amp has been sat unused in a shed for a good 18 months. He took it out recently, and played at low volume it blew the mains fuse.
I've opened it up to take a look, changed the fuse and replaced a dodgy power tube grid resistor.
It powered up and passed a signal OK, but the output was heavily mismatched, almost flat on one side.
I noticed that two KT88s (EH) were much cooler to the touch than the others. All pin voltages seemed the same, so it suggested to me that these were dead.
Removing the two left KT88s and putting one of the right KT88s in its place meant the output was a decent sinusoid, although one side took about 10 seconds and some signal to amplify that half of the signal.
I think the KT88 quad was new to begin with. Are these others dead? What is this failure mode? I am new to KT88s and I don't think I have come across a valve that fails in such a polite manner, i.e. just sits there and doesn't do anything. I am used to EL34s redplating and causing problems.
