New Month We are at $183.35 this month in Donations.Please consider making a donation. :)
Happy NEW YEARS!!!!!!
Unless otherwise specified, pots seem to have a default tolerance of 20% for the track resistance, so it's almost certainly within the manufacturing spec.
Assuming that the application is a regular Fender type tone stack, as it's a 10% audio taper, I can't think that when set to max, 210k would be noticeably less bass than 250k.
Download Duncan's TSC to investigate.
Pete
Pete
I'm just trying to figure out why the Vibrato channel on this SF Twin is so thin sounding ,and doesn't seem as loud at the normal channel. The pot is the first thing I noticed that was off some.
I thought the same thing but didn't type it.
A scope & a signal generator would come in handy for this one.
Hey Jazz ! I've been accumulating test equipment. Unfortunately none of it is in working order yet. The scope arrived damaged ,and I await another one. I have a signal generator ,but I need to test it to see if it works. Fact is I may have a bunch of spare parts
I think this was it . I disconnected the bright switch completely ,and there is a world of difference. I also found the wire connected from the bright switch to the volume control hanging by a thread. I will reconnect the switch this evening ,and go from there.
I still seem to be having issues with the Vibrato channel. Maybe the bright switch is just bad. I swear when I disconnected it it was back to normal. I may have to try it again to see if I was hallucinating. I also had a very bad hum with the Reverb on. Found a broken wire in the tank, fixed that. Reverb works ,but still has a hum when it's switched on. What would cause hum in this ?
